Hey Guys-
Here are answers to everyone's questions...
Quarashi:
The locked out position fells nice and stiff. It is pretty much locked out. I did a little 12 mile loop on Saturday that involved a climbing up a steep paved road and some singletrack. Standing up to climb felt awesome, definitely helped with the mushy feeling of the AS-X. I wish it would lock it out a bit more, when climbing in the 24 ring the pedal feedback is still pretty bad.
Prexus2005
I think I saw you at Mammoth. Do you have BB7 brakes?
Yes, I did the replacement myself. I have the Yeti Ratelink tool and as long as you follow the instructions pressing the bushings in is a snap. I also replaced all my pivot bearings at the same time. That made a huge difference in how the bike felt too.
The hardest part of the install was getting the busing lined up on the eyelet closest to the reservoir. The Yeti tool doesn't seem to have a way to center that bushing perfectly. Luckily I could press it in by hand and make minor adjustments to get it in.
Damon
The ROCO uses a standard shock pump. I'm using the Fox pump that came with my 575. So far I've only used the lock out setting and one click in from full open. When I ride on Thursday I'll try the middle settings. I'm running a 170mm Marzocchi 66RC2X. When I bought the bike it had a Sherman Breakout Plus. I would highly recommend getting rid of that ASAP! It is by far the worst fork I've ever used. If you can afford a 66 or Totem it is well worth it. JensonUSA has the 66RC2X for $529 right now which is a steal.
http://www.jensonusa.com/store/product/FK402A14-Marzocchi+66+Rc2x+07.aspx
My major compliant is with the rebound adjustment. Of the say 15 clicks of adjustment, 1-14 are all about the same, super fast, and 15 is way too slow to be usable. Luckily Marzocchi USA is a just up the road from me and I'll be taking the shock in to have it looked at pretty soon.
