1 - 9 of 9 Posts
· Registered
try Mesotony
You should talk to Mesotony. I think he's spot welded his Remolinos, but left about a 1" gap between them. He's running twin Endomorphs and it looks cool! Its kinda like duelies on one of those bigarse pickups that routinely try to run me down on Elmore.
Oh wait, his rims are red. Sorry dude :madman: Oh well, good luck with your search.
Ak29
· Registered
RedRim RedRim
AK29....sure, casually cast your dispersions on the RedRims.... just remember backwards its Mirder...Mirder...
good thing its not a fixie and I can't ride backwards...
· Caveman
Discussion Starter · #5 ·
Planning on sewing together 2 endomorphs.
The problem is that I need a 280mm spaced rear hub, luckily Dylan knows his way around a lathe and bearing press so that is in the bag.
So next up is the frame to handle such obesity. Mikesee told me that I was out of my gord, the fatback isnt fat enough and even Surly disowned me, so the obvious solution is to use copper tubing and plumbing fittings.
The rolling resistance should provide enough heat that the copper lugged frame will act as a radiator, and I'll be able to ride mostly naked in even the coldest of temps.
So I guess that brings us back to rims - ok, ok I'll take anodized citrus and I'll step it down to 180mm.
Please help - I really just want to ride my bike on snow.
· Registered
i'd suggest that you drill out some small holes in the tubing. then you can fill a grease gun with melted butter and inject it inside your tubing. the heat you generate while riding will keep it from freezing and then when you need calories you can just unscrew a little valve and hold a bagette, or your mouth, under the tubing for a nice snack.
· Neve_r_est
Butt butter.
Copper: rust resistant, compliant, you could repair it with a roll of solder and your penny stove, whats not to like?
You should lace those wheels up to a gearhub or two and don't forget the Hammerschmitt to complete that perfect build....
1 - 9 of 9 Posts
