I'm looking to try a different rear shock on an 05-X5. Thinking of an 06 Pushed RP3 - seems like a reasonable purchase.
My question is that Pushed asks what frame mfg., model and year when you order the shock so all mounting spacers are correct etc. What I'm not sure of...how is the large, upper spacer pushed/mounted through the top shock eyelet? It's that large aluminum shaft the mounts horizontal between the rockers and has the large bolt passing through it? Unassembled, it has a smaller diameter in the centre, so I'm not sure how one mounts the shock to it. Is it press fit with bushings? Is it threaded in the centre and you pass the two halves through the shock eyelet? Not sure, never had one apart.
Just want to know what I'm getting into before I place an order and end up destroying something in the process.
