1 - 4 of 4 Posts
Installed new pads, basically no clearance now from pads to rotors. Rotor is centred between pads, so I cant adjust aligment.
Do I have to bleed out fluid now ??? other alternative may be to do a few rides see if they clear. Did a 25km ride still no difference just tired legs from pushing the extra resistance.
Adjusted lever movemet still no diff.
What WiLL said 'cept I'd use a tyre lever as there's less chance of damaging something if it slips.
XSL_WiLL said:
You have to push the pistons back into their bores. Use a pad spreader, or pull the pads out and use the end of a box-wrench.
1 - 4 of 4 Posts
