It's not very original but it's a 2021 Specialized Epic Expert size Large (100mm travel with brain version) with the DT Swiss XRC 1200 wheels, powermeter and SRAM AXS shifters off my Orbea Oiz moved across. As pictured it weighs 11.6kg / 25.7lbs including pedals so is heavier than my Oiz with the same wheels on.
What's interesting about this bike after riding the Orbea Oiz for a year is that it has a completely different philosophy to how the suspension functions. The main thing on the Orbea Oiz is that the rider can adjust the attitude of the bike suspension on the move using the lockout lever whilst on an Epic the settings can't be adjusted without stopping and getting off the bike. This ability to adjust the suspension, particularly for descents, was one of the main reasons I got an Orbea Oiz after years of Specialized Epics.
On my Orbea Oiz size Large (100mm travel stock Fox suspension with squidlock) the suspension when unlocked is relatively smooth and plush. The fork and rear shock smooth out the bumps when fully open giving a sensation of calm and inspiring confidence on descents. The tradeoff being that fully unlocked the Orbea Oiz rear suspension does bob quite a bit so it relies on using the squidlock lockout lever, particularly on climbs, for added pedaling efficiency.
The 2021 Epic brain rear shock in contrast isn't adjustable on the move so the initial settings chosen have to deal with all conditions. There is about 10mm of free stroke at the beginning of the rear shock's travel, with or without any brain platform applied. After this 10mm of free stroke there is then a massive ramp up in compression damping, which is there with or without any brain platform applied. I'd describe the 2021 Epic brain OFF feel as being like a standard rear shock with its climb switch flipped making for very little pedal bob, but also giving a firm ride. I've been riding it with the brain platform turned off all ride because that ramp in compression damping stops the suspension bobbing by itself. There's not much in the way of plushness from either the rear shock or fork. It's all business all the time.
The 36mm longer wheelbase and slacker 67.5 degree head angle of the Specialized Epic are fine. It's a bigger bike than the Orbea Oiz and feels particularly well balanced through longer mid to high speed sweeping bends and it noticeably has excellent rear wheel traction when climbing also. Slow speed handling is a little less poised than the Orbea Oiz but that's just practice.
