Cane Creek 70 and 110 has a good bottom seal.
You are right. The M8120 has those spacers. One on each arm.If you look on the Shimano crank arms the version type should be printed onto it on the inside next to the pedal hole.
I went and had a look in my garage at a new boxed Shimano Deore XT M8100 crank and it doesn't come with those spacers. The Shimano bottom bracket doesn't come with those spacers either.
There are a few different versions of the Shimano Deore XT crank arms with different q factors. The M8100 being the narrower version 172mm q factor, 52mm chainline and M8120 being the wider version 178mm q factor, 55mm chainline. The M8100 doesn't have spacers but I'm wondering if the M8120 might have a longer axle and then spacers added on each side to achieve that 6mm wider q factor? That could explain why your crank has spacers on perhaps if it's the wider M8120 version.
Shimano XT 12-Speed Cranksets
Reviews, ratings, specifications, weight, price and more for the Shimano XT 12-Speed Cranksetswww.vitalmtb.com
I don't have an M8120 crank on hand to check for sure.![]()
That’s a good spot. It looks like there’s an additional rubber o-ring seal on the crown race that sits on the fork crown with a Cane Creek 110 headset.Cane Creek 70 and 110 has a good bottom seal.
That sure does look like rust.I haven't got my Orbea Oiz frame or fork here at the moment (it's still at the bike shop waiting for the warranty suspension parts to turn up.)
To illustrate what the default headset sealing looks like these pictures show the lower bearing and fork crown race of my 2012 Specialized Epic. It has the same layout as an Orbea Oiz. The lower cartridge bearing sits on the fork crown race and when the headset is pulled tight the bearing slots into the moulded carbon fibre hole in the bottom of the frame head tube.
The cartridge bearing has a rubber seal covering the bearing but there is no seal between the frame and fork crown race so there is a small gap there allowing dirt and water to get inside to the bearing.
With this particular headset and fork in the bike has only been ridden outside a few times as it is usually a dedicated turbo trainer bike. Even so, there's a bit of dirt visible in the headset around the bearing in these pictures.
The picture is a bit misleading because it had the flash on to show the inside of the head tube. What you can see is that red grease mixed with dirt on the outside of the bearing, rather than rust.That sure does look like rust.
As that’s mainly a trainer bike is that from sweat dripping down through the headtube?
I too have a similar issue as yours but mine still makes me in doubt if the frame didn't crack too.I took the bike fully apart today to look at the state of the bearings and swingarm threads. I've attached some additional photos showing the fully disassembled drive side bearing and threads of my 2020 Orbea Oiz.
The rear view picture shows that when the main pivot bolt is fully tightened the drive side bearing sits on the threads of the pivot bolt, rather than on the solid metal part of the pivot bolt. There is no spacer on that side. With the bolt installed all the wear on the anodising is at the bottom of the bolt.
The drive side bearing is gritty but not completely seized with the swingarm removed. The non drive side bearing is also a bit gritty but in better condition than the drive side bearing. When assembled with the swingarm in place and the worn pivot bolt it looks like there is a lot of slop exerting uneven pressure on the bearing however. When riding it would most likely be seizing up fully as the swingarm twisted to the side.
The threads into the swingarm aren't great but aren't completely stripped as once cleaned out the bolt would thread back in. The threads are worst at the bottom of the swingarm where it has been sitting at an angle instead of square with the drive side bearing. It looks like the swingarm has been rubbing on the frame/ edge of the bearing.
My bike is still at the bike shop at the moment. I'll take some pictures of my frame's bearings to compare with the next time I'm there.I too have a similar issue as yours but mine still makes me in doubt if the frame didn't crack too.
My main pivot bolt on the drive side bearing bed clearly got "destroyed".
My doubt is... To you, does the frame look ok on that side? Because to me I'm in doubt it that is only cosmetic or not.
Pictures attached
Please keep us posted on what conclusion your LBS and/or Orbea come up with.I took the bike fully apart today to look at the state of the bearings and swingarm threads. I've attached some additional photos showing the fully disassembled drive side bearing and threads of my 2020 Orbea Oiz.
Something I realised was that although my bike's main rear suspension pivot bearings moved and initially rotated roughly when I first took the bike apart they might have been freed up by the process of removing the main pivot bolt. The next day after sitting overnight they were seized and after a month hanging up in the bike shop are stuck solid. Thinking back there was a definite "pop" the very first pedal stroke at the beginning of the ride from the rear suspension for a few weeks previous to the pivot bolt coming out, as though the bearings were sticking and that first suspension compression was breaking them loose.I had some rust visible just above the drive-side bearing and given what you guys showed here I was curious about what's going on on my Oiz. Took it apart, it was quite dirty. The bearing aren't running smooth, but not too bad either.
Here is a picture of the bolt. I guess the width of the wear marks show that the drive side bearing rests partially on the threads.The bolt is supposed to be tightened to 25 Nm. I didn't even go to 25 Nm and it was sticking out on the drive side. WTF?!?! See the bottom half of the picture, where I put on the chainguide to illustrate by the gap how far the bolt sticks out. If tightened to 25 Nm it would probably stick out 3 millimeters or so. And no, I did not forget the non-drive side washer.
I feel very ashamed about it.What I thought was interesting in your frame drive side bearing picture is that there's lots of corrosion visible internally. The sleeve inboard of the bearing has a lot of rust on and there are what appears to be water droplets in there too from the reflections. It looks like the bearing has been sat in water and rusted from the inside. The other two bikes drive side bearing pictures have much less corrosion on the inside and clean-ish looking sleeves. It might never have dried out fully since that hypothetical lake submersion months ago!
