I just got in my new 2006 Marzocchi MX Pro ETA TAS fork. In trying to get it all adjusted out, I can't seem to find full travel. With the lower left TAS knob dialed counterclockwise all the way, and the stanchions showing 120mm between seal and crown, I can only get just under four inches of travel. In fact, regardless of setting (100mm or 120mm) I am still leaving about an inch at the top of the stanchions thats not being used. I am testing travel by pushing down, extremely hard, on the handlebars. All my weight, almost breaking my handlebar.
I am considering taking the right leg apart (top cap off) and draining a little amount of oil out. It is a new fork, and I wanted to see what you guys thought before I tore into something that should be pretty good on the inside. Also, if you do think I need to drain a little oil, should I do both legs, or only one. Thanks for the help, and sorry for the long message. Just wanted to have in the details.
