Colorado-based Feedback Sports is well known for its bike stands and bike storage products. Last year, the company entered a new market with the Omnium portable trainer and have continued to expand, acquiring the popular Scorpion Stand.
Now Feedback Sports is getting in to the wrenching game with a tool collection that's highlighted by the Team Edition Tool Kit, and also includes the less expensive Ride Prep Tool Kit and a complete set of T-handle wrenches.
Feedback Sports Team Edition Tool Kit
The Team Edition Tool Kit is designed to put all your maintenance essentials in a convenient position that is easy to travel with. The kit has 19 tools that serve 25 functions in a self-contained case that hangs easily from your workstand - or a hotel room tool hook. Simply unzip the case and hang it and everything falls into place.
Tools are professional grade. The molded grips provide a secure and comfortable grip. The TPU nylon coated case holds all the tools securely and even provides room for extra tools (like Feedback's new T-handle wrenches).
The kit includes: fixed 3-way Torx t25/27/30, fixed 3-way hex 2/2.5/3mm, fixed 3-way hex 4/5/6mm, l-hex 8mm, l-hex 10mm, #0 Phillips, #2 Phillips, 6mm flathead, Schrader core tool, Presta core tool, valve extender wrench, spoke wrench, chain pin press, rotor truing tool, crank arm cap tool, steel core tire levers, brake pad spreader, 15mm pedal wrench, 15mm axle nut wrench, bottom bracket wrench, cassette lockring wrench, cassette pliers, cable cutter, cable crimper and dual sided pick. Price is $250.
Feedback Sports Ride Prep Tool Kit
The Ride Prep Tool Kit offers 12 tools with 16 functions for the rider whose maintenance and repair needs are more basic. Like the Team Edition kit, this set provides professional grade durability and a limited lifetime warranty. The case is made from the same TPU coated nylon.
Included tools for this set are: fixed 3-way TORX T25/27/30, fixed 3-way Hex 2/2.5/3mm, fixed 3-way Hex 4/5/6mm, L-Hex 8mm, #0 Phillips, Schrader core tool, Presta core tool, valve extender wrench, spoke wrench, chain pin press, rotor truing tool, crank arm cap tool, steel core tire levers, brake pad spreader, 15mm pedal wrench and 15mm axle nut wrench. Price is $130.
Feedback Sports T-handle Tool Kit
The new T-handle Tool Kit from Feedback Sports is almost as pretty to look at as it is functional. The polished S2 steel gives you peace of mind from its pro grade durability. The weight of each wrench adds to the quality feel.
The seven wrenches are: T25 TORX, 6mm Hex, 5mm Hex, 4mm Hex, 3mm Hex, 2.5mm Hex and 2mm Hex. Price is $130.
More info on all three of these tool sets can be found at www.feedbacksports.com.
