No you can not.Hi,
Does anyone know if the new EXP ratchet is compatible with old 240s hubs ? Can I upgrade 240s with EXP ratchet ? Thanks.
The real dt ratchets don't have problems in the real dt hubs (240s).Thank you guys. I thought that it would be a no go. Just wanted to be 100% sure.
In fact, I have ZTTO M1 hubs (DT240 knock offs). And I have a problem with ratchet springs grinding into the short axle. The EXP system would solve this as it have only one spring and it is not conical.
I will try to buy original DT ratchet with new springs, maybe it will solve the problem.
