1 - 20 of 31 Posts
fork: Fox 36 (Float or Van)
cranks: Saint, XT
guide: MRP sounds fine
brakes: Saint
Wheels: I like tubeless. I am running 823 currently, but next wheels on order are ZTR Flows. Lots of hub choices depending on pocketbook: Hadley, King, Hope etc. I actually like the Saint hubs a lot as well, allows you to use centerlock, which is far superior imo to 6-bolt.
You are going to love the Delerium!
For brakes, Saint calipers at the very least. As much as people laud the formulas, I just don't like the mushy modulation.
I'd go with a fox 36.
I didn't think too hard about cranks. Your bike is going to weigh upwards of 35lbs anyway.
I am loving the 2012 talas 180mm. Adjustable travel is an important feature for me, if it was not I would have gone with a float. I really liked the lyric uturn coil on my endo but wanted a 180mm fork on the delirium for park days and bigger stuff in general.
Cranks: I am running 1x10 at the moment with an mrp g2. I really like 1x set ups but I may switch back to a 2x10 as extended steep climbs are tough. I have no real preference as far as brand.
Brakes: I have always liked hope brakes and am running x2's with 203f & 183r. The only other brakes I have any recent experience with are formula k24's. So I can't really be of much help.
Wheels: I currently have hope pro/ex500 rims and they are a good wheelset. I do not like the poe of the rear hub, it feels wierd on stutter step climbs and those times when you need to turn the cranks a fraction to aid in balancing in technical situations. Anyway that is a long way of saying that I wished they engaged a littler quicker. I have just ordered a set of hadley hubs laced to flows.
I am running tubeless (stan's) and have very light tires with no issues. I will be using bigger meats for park days.
Awesome bike, enjoy it.
What is the intended use? What kind of build are you coming from?
I use my D for AM/FR duties, with only a change of wheelset for the heavier stuff. That being said, when I moved from another 6" bike to this one, I went 1x9 and dropper post, which have both entirely changed the way I ride.
As for bits...shimano cranks are the easiest to set up, Magura brakes are the most reliable in my experience, fork is personal preference...
First thing...
....is to turn the shock resevoir down. Gives you more room to handle your bike.
- Fox Float 180 or 170. A great fork that feels as close to a coil as you'll get these days with the lightnes of air. Great feel and function.
- Good set of light wheels. People are selling good wheelests for cheap nowadays and rotational weight and strength make a huge difference. i.e .... 823 / Hope 2 Pro(RED) 20mm/135-Bolton or 142x12 - Pinkbike.com , Dt Swiss wheelset - Pinkbike.com
- Cranks are pretty much what you want. Saints are sturday and semi-light. Descendents are crazy light and pretty sturdy. Race Face can be tricky to install and take off, but good cranks.
- Brakes depend on your use. The Ones are great, but pricey. Avid has a great selection for whatever you need. Hope's/Magura's are good brakes, as well.
- Go 1 x10, no discussion. You can pedal this bike pretty much anywhere and it'll make you stronger.
- E-13 or MRP either works for a guide.
- I like the seat dropper for quick terrain changes. If you are pedalling uphill and then going straight DH, then you don't need the extra weight and cost. Until the KS Lev comes out, the closed system of the Reverb is beneficial for the winter conditions. The mech systems of the others get gunk in them from the wet conditions and can stop functioning.
- Stems are dependent on your riding style. More AM/FR shorter stem...Thomson, Chromag or Point 1. AM/XC = longer and Thomson, RF or the new Point 1.
- Bars are getting wider. I like the Chromag and my friend likes the Race Face. The sweeps are nice on both.
- Pedals. Point 1's are durable light and have a great platform. Nowadys there are so many, it's more of a personal preference. Twenty6 are light and nice, but pricey and if you ride in rocky terrain I wouldn't get them.
Good luck and post up some pics and ride reports.
I'm going to assume you're building it as a heavy AM/light free ride ride. Here is what I would get (mostly because it's exactly what I have).
- Fork > I'm running the 180 Talas and I really like it. It's a bit more playful than the 66 or Totem but burly enough to handle some solid free ride. I never drop the travel so a Float180 would do just fine as well. I have not tried this bike with a 160 fork.
- Wheels > I'm running the Stan Flow's with Hadley hubs. They are light and strong and they to do tubeless very well. I had 5.1's and Mavic 721's before. All worked very well. The Stan's is the lightest and best for Tubeless though. I do love my Hadley's but I have I-9's on my other bike and I like them better.
- Cranks > SLX if you are on a budget and want some solid cranks at a good weight. I'm trying the SixC cranks on my Chili.
- Drive train > 1x10 all the way. I've converted all of my bikes to it using the MRP G2. I never have missed having granny and my drivetrain lasts longer.
- Brakes > I'm a big Hope fan. I've had good luck with the M4's with 203/160. I only felt under gunned occasionally. I think I'll bump my rear to 203.
- Pedals > If you deal with rocks then you want to choose carefully. I've blown through Straightlines, Twenty6, Wellgos in less than a season of riding. I'm running the PointOne's now and I have had good luck with them.
I'm starting the build this week of a 2010 Delirium and have some questions about certain parts. I'm looking for recommendations on the following components:
Fork
Crankset
Chain Ring Guide (I'm leaning towards the MRP 2X)
Brakes
Wheels (Does anyone run tubless on this type of bike?)
Thanks.
Fork: I have run my Delirium with a Float 160 RLC and 180 RC2. If you want a more AM bike, go with a 160 and set the shock in the top position. The 160 is more balanced overall and BB height is higher with fewer pedal strikes. The 180 with the shock set in middle position works better in rough DH situations and slightly less fun for trail riding.
Crank set: I bent my XT's and now run Saints.
Chain ring Guide: I like MRP
Brakes: Shimano fan here. Saints are the best I have tried.
Wheels: I don't like tubeless. I have a couple of friends with injuries due to front tire burping, deflating and causing bad crashes. If you are hard on wheels, do a custom build with brass nipples and straight gauge spokes. Hubs: King, Hadley, Hope are all excellent. I like my Syncros DS28 rims so far. Mavic makes great rims also. Neither of these dent like some rims on the market.
x2 on the Point One Podium pedals. They are tough, grippy works of art. They don't spin fast, but I happen to like that.
Have fun with the build.
I think the Point Ones are sick in terms of grip and feel, but I have had bearing/tolerance issues with them, and I ride in dry conditions. They are also slow as molasses when you have to pedal any where. They would be perfect for shuttling though.
Discussion Starter · #10 ·
~~~~~~~~UPDATE~~~~~~~~~
Here's what's ordered so far:
Fork: Fox 36 TALAS 180mm 1.5" taper FIT RC2 (Black)
Handlebars: Loaded AmX (Blue)
Grips: ODI Ruffian (Black /w Blue Clamps)
Stem: Thomson (Black)
Saddle: Chromag Lynx (Black)
Seatpost: Thomson (Black)
Seatpost clamp: Straitline (Blue)
Pedals: Straitline Platform (Blue)
Cranks: Saint
Brakes: Saint
Drivetrain: Saint 1x10
Chainguide: MRP G2 SL (Black)
My wheels are still up in the air depending on the availability of hubs.
If anyone thinks I'm making a fatal mistake on any of these products, please let me know.
Also, what size bolts do you have in the hubs?
Thanks.
Perpetual Hack
20mm front and 10mm x 135 on back. I run two rim sets and both sets use a DT Swiss RWS. If you go with Hadley, they have a sweet 10mm axle...
My current wheelsets are DTSwiss 340/5.1 for Gravity and and Hope/Mavic819 for trail. Tires are Schwalbe Big Betty / Muddy Mary in various combinations depending upon conditons for Gravity. Trail riding, Schwalbe Hans Dampf.
If I had to build two wheelsets for the Delirium - with my weight north of 200lbs...
Hope/Mavic 823 for Gravity
Hadley/Flows for Trail
...although I am intrigued by some of the new Spank rims, as well there are some new tubless ready options in the pipe...
I would also consider a dropper post, they are a huge boon, especially if you ride ravines, or similar up and down terrain. I traded a dropper fork for a dropper post, and have never once wished I had the fork and not the post. I keep the Thomson in the travel tool-box for a backup - never needed yet though. ( I use both an AMP and a Reverb for dropper posts )
Other than that, good looking build. Mine was bought before the Fox 180 became available, but I run a 170 Lyric Coil DH and the frame in the middle position for trail and full slack for gravity. ( Large frame, 6'2" rider )
Mine is now sitting at 35.35 lbs with the trail wheelset.
Your going to love this bike.
michael
Touchy topic on tires. I run Flows on my El Guapo. I was running Ardents converted tubeless, I had no problems with the old style (standard sidewall) and I ride mostly technical/rocky terrain for over a year. This year I got the new EXO casing Ardents and blew two of them off the rim while riding at speed (both fronts too). On a bike like the Delirium which pushes you to go faster, I would recommend a true UST bead tire. Trust me, having a front tire blow off at 20+mph is SCARY!
Cane Creek 110. That's what I used on my Turner and it's been solid. Not sure on the tires. I'm getting Stan's Flow rims. So, I would like a lightweight tire that I can run tubeless. Any thoughts?
Kenda 2.5" Blue Groove or Nevagal have never misbehaved on my Flows, setup tubless w/ yellow tape, probably around 22psi.
Minion 2.5 DHF EXO has blown off the rear a couple times for me, so they never go up front. Otherwise, a great tire.
I am running wtb Bronson 2.3's ( race version) they are super light and after running them since march set up tubeless on my endorphin, overall I am very happy with them. I have a pair of conti trail king2.4's that I am going to try on my new wheel set on the delirium.
1 - 20 of 31 Posts
