1 - 4 of 4 Posts
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
Tire Bicycle Wheel Bicycle wheel Bicycles--Equipment and supplies
Blue Bicycle part Water bottle Gas Bicycle handlebar
White Light Automotive tire Azure Bicycle part
Tire Bicycle Wheel Bicycles--Equipment and supplies Bicycle wheel
Wheel Bicycle frame Plant Bicycle part Paint
Selling brand new 2021 Custom Yeti 29 in wheels size medium. Front travel 160 mm rear 137. The only stock parts are bottom bracket seat & Fox seat post Brake set is also stock with larger rotor in front & added the oil slick bolts. . I've even replaced almost all the frame bolts with ti oil slick including on the switch infinity & shock mounts. All bolts came from Better Bolt.You can go to Yeti site for all info as far as frame geo etc. It's never been ridden. Parts list includes: i9 wheelset Chris King headset Yeti bars axis GX GX carbon cranks multi color i9 stem with blue ti bolts Wolf Tooth through axle Sram Eagle XX1 oil slick cassette & chain Absolute black ti color oval ring XTR pedals. I9 valve stems etc. etc. I also have a extra axis battery ready to go. Also new back tire extra with it. I've got other extras also. $6000 Thanks.
Tire Bicycle Bicycle tire Automotive tire Green
Automotive tire Rim Gas Automotive wheel system Automotive design
Wheel Automotive tire Automotive design Bicycle part Vehicle
Bicycle Tire Bicycle wheel Wheel Crankset
1 - 4 of 4 Posts
