hitek79 said:
It's an LX FD, but a Direct Mount, or E-Type. It bolts straight into the frame, so from what I can tell there really isn't much adjustment up or down. The only adjustment is the H and L limit screws.
The high and low limit screws are the only adjustments
on the ft. derailleur,
but they're not the only adjustments. The most important adjustment is the cable tension, or trim barrel. It usually isn't actually on FDs, but in-line someplace along the cable run, usually on the lever or at the first fulcrum (housing stop) on the frame or in-line on the housing near the lever
The limit screws do just what their name implies, set the inner and outer limits of travel, but it's the trim adjustment which determines where the FD cage is for each click of the lever. I usually adjust this to center the cage over the middle ring at the second click, then fine tune it for optimum shifting, trial and error.
The other adjustments are height and rotation. Within the range of movement afforded, make sure the cage is parallel with the chainrings and as close to 2mm above the outer chainring as possible.
