So, I haven't ridden them back to back. And it isn't a Ciclon I've ridden, it's my Chucho. And the riding I did on the 5-spot was last year. But I'll give you my feelings about the two bikes. The Chucho is the same as the Ciclon, just with a 29er front wheel. Rear ends are all the same.
When I went to Interbike last year I was looking to ride the 3 DW link bikes, Pivot, IBIS, and Turner. And really, I wanted to like the Turner the most as I sell Ventana's already, and Turners are obviously talked about in the same breath as Ventana. US made. killer trail bikes, etc etc.
Pivot Mach5 was the most Ventana like. Rock solid. Climbed the technical stuff good. Back end felt stiff in the corners. The suspension really felt a lot like my version 1 Chucho I was riding at the time. But it was heavy, and felt that way when you pedaled it. Just was not an 'exciting' bike to ride in the least.
IBIS Mojo was the most fun bike of the three. Climbed ok, although when pushing the pedals hard on the climbs it got mushy side to side enough that I could feel it. Only in those instances where you have superb traction and your loading the bike hard to make it up and over a rock face could you feel that push and twist. It was a fun bike to downhill on. Just think about going here or there and the bike instantly got there. So easy to jump from one line to the other. Bike was light feeling. Downhill turns where you're hard on the brakes, like into a decreasing radius turn, the front end would push a good amount do to front triangle flex. At speed this bike was a blast to descend on for short distances, but I imagine on a longer downhill it would get a little tiring having to pay so close attention to the bike. Is not a 'planted' riding bike at all.
The Turner...what can I say. I was disappointed. It climbed like a hardtail, seriously. Like spinning the tire over ledges and on the loose stuff. Definetly not a strong technical climber(neither am I which is why I am so critical of bikes here). When you were on the gas hard the suspension did not move. And when you did have enough traction, and proper body position, to load the rear end while climbing up something in the small ring, when that suspension did activate you felt it in the pedals. Annoying to say the least. I have enough problems getting my xxl frame up a hill, I don't need the pedals giving me the feeling of instantly stopping. Once you were over the hump and getting into the downhill the bike just seemed to wallow down into deeper part fo the travel quickly. Not a great feeling. I played with settings a bunch and went for an extended ride trying to get it to a point where I'd like it. I really wanted ot like this bike! Went back to the tent and discussed things and had the tech set it up. But to no avail. It still felt like Doctor Jekyl and Mr. Hyde.
So, I carry IBIS and Ventana now is the long and the short of it.
I do have to say that the latteral stiffness of the 5 Spot is very good. This, I was impressed with. The rest of the bike, not so much.
The new Ciclon/Chucho with the upgraded pivot location, oversized seat tube/downtube/hydro top tube/tapered ehad tube, has taken a pretty large step forward over the older designs. The bike stays up in it's travel a lot more. Can't say it 'feels' as 'plush' as the version 1.0, but then again it not sitting in the mid stroke is a great improvement for pedaling efficiency. And with it staying higher in the travel I feel that it steps up over ledges climbing much more easily. Where version 1.0 felt like it hit into the travel a bit deep before the wheel hauled up and over the ledge, the new pivot location seems to initiate into the travel, then the back wheel follows up it quicker, keeping the bike higher in the travel and loosing less momentum.
The rear end lateral stiffness has also increaded. Amazing, but true. On my last ride there was a tough middle ring climb section up over some rocks as you were going between a few trees. I had the bike loaded up in funny directions while having to be on the pedals hard. It was amazing how much that back tire was grabing and twisting all the while I could feel that energy being transfered through the front triangle almost into the bars. It's one stiff frame! There was no defelction going on at all. I was making that bike do something that should have had it flexing a good amount, but no way. That was the first time I really thought, 'Wow, this bike IS stiffer." It may be hard to convey in words, but I could feel the front and rear triangles working solidly in a straight line as I was honking the bars to get up and over and through and the rear tire grabing and biting sideways this way and that. It was kinda cool!
I do have to say, and it may just be a set-up thing, I don't think the version 2.0 is as plush. I mean I get done with a ride and think, "Hrmm, maybe I should let a bit of air out of the rear to soften it up", but then I look and the travel ring is near the bottom of the shock stancion, so I guess not. Not that it's rough and bouncing me off line by any means, just not as supple as version 1.0 felt.
The new bike feels faster all around though. More efficiant. And stiffer!
Anyway, there's all I have to say on that topic for now.
