Finished building last night, and had a few laps on the trails today (Yep, I was sick...cough... cough...)
Still to early to tell the whole story, but it felt really good. There are still some issues to work out, but all in all I am pleased with the outcome. The wife has started calling it the "Tractor"
after reading RC's 29r's On the bubble in MBA. Heres the build up.
29r IF with EBB
RS Reba w/ poplock
Easton monkey bars, Thompson cockpit, Hope mono mini's w/ 2 piece rotors
DuraAce Ti cassette 12/25T, DuraAce derailluer, XTR cable and housing, Paul's thumby
Raceface Deus 180mm arms with 34T Salsa ring, Speedgoat / Dangerboy bash guard
The wheels are Bontrager Mustang OSB's laced with Wheelsmith 14/15 spokes to Hadley hubs. The rear hub uses a 12mm thru axle. These are wrapped with tubed, wire beaded Nano's. (green stripe)
It is a bit heavy at 27 lbs. but there is room to tweak. I usually ride light SS, but have always needed more gear to stay with the gang on the route to the trail or on those fast flat sections. I think the 1 x 9 will be just the ticket.
I did have a question for you Reba users...The fork "chuffs" really loudly when it travels. I am a 200 lbs'r, and have it set at 140 psi pos / 130 psi neg, with 75% rebound cranked in. Is this a break in issue or will it continue? The fork feels fine, and gets quiet if you back off off on the rebound, none of my other RS forks do this?
29r IF with EBB
RS Reba w/ poplock
