Seat is 27 5/8" from center of crank spindle to top of center of seat (centerline of seat mast).
Frame is a medium
Chainrings are Extralite Octaramp 44 and 30
I did "alter" the seat clamp blocks to fit the SpeedNeedle. It was pretty easy with a Dremel and sanding drum. I was actually surprised how easily the aluminum sanded.
Tires are Continental SpeedKing Supersonic 2.3 on the front and Race King Supersonic 2.2 on the rear. They are not tubeless per se, but running the Stan's No Tubes sealant on No Tubes rims.
Yes, the FD is a Campy Record Ti Compact braze on with the Parlee clamp. The clamp was actually cut down slightly as it was originally mounted on my Anthem Advanced, and because of the pivot points on the Giant, I needed extra room to slide the clamp as high as possible. Don't know for sure what the pull ratio would be on the Campy, but as you mentioned, since the shifter is a Sram twist shifter, and I'm only running 2 front chainrings, it doesn't really matter to me. At first I had the 3 rings from the XTR crankset on the bike, and just riding around before the bike was really finished, I could easily shift between the 22 and the 32, and they both seemed to line up pretty well with the numbers on the shifter, but the FD didn't have enough throw to pull the chain up onto the 44t. Now that the 44 is mounted where the 32 used to be, its no problem really. I also made a small 1.8mm carbon spacer to move the crank assembly slightly further out on the drive side. Seems to work really well.
I'll call Chris at Enduro right away. I really want to use the Clavs.
Thanks guys.
