You're reading too much into what I said.
A DW-Link bike is going to extend the suspension under chain torque anyways, and a traditional lockout would ensure that it stays extended...so the line valve is overkill, and maybe even not what people actually want, since it would allow the suspension to compress, which the chain torque would then extend, meaning that torque is turned into heat in the shock instead of power to the rear wheel.
I do use my dual lockout a few times during a ride, does it really feel like it makes a difference? Hard to tell, but I get that any flex, any chain torque influence on the suspension is the bike absorbing force, which means that force isn't turned into power. That really matters at the highest levels of sport where the competitors are more evenly matched...but with amateurs, when it comes down to it, luck matters much, much, more than the truly marginal difference provided by a $1,000 electronic lockout.
That's why I think it's a bit much.
(like AXS, I'm sure it shifts better, but not necessarily $800 derailleur better...if I hit the lottery, my opinion might change)
DW doesn't extend the suspension under chain torque, the anti-squat keeps it from compressing under chain torque. That's different because if it was making it extend, it would be opposing the bumps at the same time. Fighting the bumps and extending during pedaling is what you get when you are significantly above 100% anti-squat, like old high-pivot designs (orange, santa cruz, mtn cycle, etc.). The other feature of DW is that this effect is the same at the sag point as it is significantly deeper in the travel, accounting for weight shifts, more sag, the suspension working through bumps, etc.-meaning it pedals consistent in a wide variety of situations.
The blur, mentioned above, pedals very similar, has a very similar AS profile.
For racing XC, it doesn't matter if it's already an efficient design. You are literally throwing the bike, mashing the pedals, making explosive bursts of power, pushing down and pulling up so hard that the suspension activates. You don't want it to activate, you want all of your power to go towards moving you forward. Even on the most efficient bikes, it's not like riding a hardtail uphill of you are running the lockout open. A lockout makes it much closer to like a hardtail uphill or on smooth ground. Don't take my word for it, look at what all the pros are running. And don't look just at the pros, look at what 1-10 of the expert class is running. If by "amateur", you mean sport and beginner...well there it starts to matter much less what kind of bike, travel, etc., you have. Many people will be just as competitive in those classes on a wide variety of bikes and setups, because their fitness is more of the limiting factor. When you are XC racing, the higher the level, the more advantages you are looking for. Each advantage adds contributes to the bigger picture.
I would agree that you don't need an electronic lockout, no doubt that would be a nice luxury, but for XC racing, what this bike is designed for, not just pro levels, it's an absolute necessity to have some kind of lockout IME.
