1 - 20 of 25 Posts
Resident Texican
Discussion Starter #1
For those who don't follow the "How was your commute" thread, on Monday morning I was hit by a fellow student while on campus at UTSA. As a result of this I am now in the market for a new commuter and all-purpose enjoyment bike.
At this point I know pretty much what I'm looking for in the bike, I just am trying to compare the geometries of the few that I'm considering. The three front-runners are the All City Macho Man Disc, Salsa Vaya 3, and Salsa Fargo 3. It seems that All City and Salsa size their bikes by using seat tube length and ETT, respectively. So, that means that 54cm Vaya is about the same size as a Small Fargo and same thing with the 49cm Macho Man.
What I need is a bike with approximately 54cm ETT and able to be set up with a saddle to bottom bracket length of about 73cm. Does my comparison of these three bikes make sense?
I don't know nuthin' bout measurin' no bikes, Miss Scarlett!
Those are all within the realm of 'small', depending on the type of bikes they are. A 54 is closer to a medium, and a 49 is closer to an XS, but again, I'd impress that these manufacturers do funky things with sizing, sometimes. Best bet is to throw a leg over it to find out.
As far as other things to consider, what do you want? Drops? Flat bar? Single speed?
I am about 5' 8 1/2" and I ride a 54cm Vaya. I think a 55 would fit me too.
Consider that the Fargo is essentially a drop-bar mountain bike and the Vaya is a touring/ gravel bike. How much actual dirt do you plan to ride?
Recently test rode a Vaya and a Kona Rove. I bought the Rove because it felt way snappier than the Vaya. ETT and ST similar to the Vaya.
My usage is 90% commuting (mostly paved), 7% d!cking around on gravel or trails, 3% touring if I get permission.
I'm happy with it for whatever that's worth.
Resident Texican
Discussion Starter #6
The issue with trying them out is that there are no shops in my city that carry either brand.
@mack_turtle if you are that height and ride a 54cm Vaya then I think either the 49cm or 52cm Macho Man should work just fine for me. The 49cm is nearly identical to your Vaya.
@wschruba I'm trying to replace my commuter, which was a Novara Buzz that I had converted to drop bars. After having that bike set up with drop bars for about the last month and a half I'm pretty sure that a drop bar cyclocross bike would work very well for the riding I do. I'm also looking for a geared bike, and I would like to stick with a steel frame.
I think the Fargo is a bit more dirt oriented that what I want. Mainly I threw that into the mix just for size comparisons. I sent an e-mail to the people at All City Cycles and will hopefully see what they have to say come tomorrow.
I'd rather be on my bike
Is the Novara Buzz still available? Why not go with what you know and like?
I have got to ask the stupid question. Are the measurements you are after ones from the Buzz you switched over to drop Bar? Or are they drop bar specific frame measurements?
Resident Texican
Discussion Starter #9
I'm looking for a drop bar specific frame. @TenSpeed, the reason why I don't want to go with another buzz is because I really like the drop bars, and I don't want to go through the effort of stripping the frame and changing out the drive-train again.
Resident Texican
Discussion Starter #11
Thanks, Harold. I too ride mediums and I figured the 54cm Vaya would be the right size for me. But, I actually was able to find a really good deal on last year's Raleigh Tamland 1 so I pulled the trigger on that. The bike shop is getting it shipped in, and luckily if I don't like it after the test ride there is no penalty to me if I don't want it. I really hope this bike fits well, because if it doesn't then I have no idea what direction I'm going to take.
mtbr Decade+
If you have a Surly dealer around wouldn't a Cross-Check or Straggler fit your needs?
Resident Texican
Discussion Starter #14
Some pics of my old bike
I figured that I would include some pictures of my old bike to show what happened to it. I should be able to salvage the derailleurs and possibly the brifters, but with the force applied to everything else I don't trust the BB, hubs, headset, etc. It can't be seen in these two pics, but the entire frame is slightly warped.
mtbr Decade+
I agree with the displaced Texan, a couple of clydes could bend that back to square. :)
Amen, lucky you are in one piece!
Resident Texican
Discussion Starter #20
@newfangled I know, what happened to the crank is pretty crazy. My tech was surprised that it didn't just snap off.
And I agree that I am very lucky to have no serious injuries. :)
1 - 20 of 25 Posts
