1 - 20 of 23 Posts
Discussion Starter #1
I am making a frame jig. It is pretty much a copy of 44bikes, pithybikes, and Tanners. I am taking a little from each.
1910431
1910432
1910433
1910434
1910435
1910436
I guess you're basing it on Pithy Bikes' original jig from his early videos? I based mine on his more recent low-cost plywood design, but using 40mm alu profile rather than plywood for the beams. Interested to see how yours looks when finished.
Discussion Starter #3
Yes his first jig. Its more of a copy of Kris at 44 bikes. He has alot of good pictures.
Discussion Starter #8
A little progress. Finished the slot for the bolt to adjust head t
1912317
1912318
ube angle and added a pointer that will reference the degrees that will be machined and laser etched in the back plate.
I've been watching this as you post it up.
I'm confused about the use of a ball bearing cartridge in the fixture. Why is this needed? A bore on a shaft is adequate for this interface. Even if you were concerned about wear, a plain bearing would make the most sense. This solution added complexity and cost for a reduction in precision. Can you explain this better?
Discussion Starter #18
yes but thinking of off setting the head tube cones over the pivot point. Still working it out.
Discussion Starter #20
Yeah I agree. It’s my first time. I will take it slowly.
if you have any recommendations let me know.
1 - 20 of 23 Posts
