1 - 4 of 4 Posts
My new Nomad frame came with a 2012 RP23 that I have ridden about 6 times so far and as of my last ride I see some fluid leaking out around the seal and collecting on the oring/stanchion. What might cause this? Seems to ride great, propedal is working fine.
normal - it is an oil bath for the shock. when you stop seeing oil on the shaft of the shock, it is time to add oil to it. this would be when the shaft is essentially dry after multiple rear compressions. might need new air seals at that time as well.
1 - 4 of 4 Posts
