1 - 10 of 10 Posts
Had my 09 Spot built up. Props to Curley and Peter @ Rage Cycles in Scottsdale for the advice on the front end and the build. Always a great shop to work with.
Kind of funny... when I first received the frame... I thought I was sent a woman's frame.
Been a great ride so far, still getting things dialed in. Also posted on setup thread.
Bike setup:
* Frame Size & Color: Small Blue 2009 DWL Spot
* Rear Shock: Fox RP23
* Fork: 2008 Fox Talas RLC
* Brakes: Avid Elixir CR
* Shifter: XTR
* Cranks: XTR
* Front Derailleur: XTR
* Rear Derailleur: XTR Shadow
* Pedals: XTR
* Stem: Thomson X4
* Handlebar: RaceFace Carbon
* Seatpost: Thomson Masterpiece
* Seatpost Clamp: Hope
* Saddle: Specialized Format
* Bottom Bracket: Chris King (Butta!)
* Chainring: XTR
* Cassette: XTR
* Headset: Chris King
* Grips: Race Face
* Front Tire: Panaracer Rampage 2.1 Tubeless
* Front Rim: Mavic 819 Disc
* Front Hub: Chris King
* Rear Tire: Panaracer Rampage 2.1 Tubeless
* Rear Rim: Mavic 819 Disc
* Rear Hub: Chris King
* Spokes: DT Revolution and Comp Spokes
* Skewers: Hope
* Wheelbuilder - Gravy
Total weight... 27.7lbs.
Bite Me.
You can tweak that banjo fitting on the rear brake caliper to get that kinky bend out of the hose. That's a nice feature on the Elixer CRs that the Rs don't have. Looks like a fun ride.
Discussion Starter · #8 ·
Still need to do some tweaking but thanks for the compliments. Glad I went with the Spot... it replaced a 2007 PUSHd Flux... I almost went with a 2009 Flux because I was thinking the 2009 Spot was sloppier than the 2009 Flux.
1 - 10 of 10 Posts
