1 - 3 of 3 Posts
Can someone using the Nevegal 2.35" measure the axle to ground height unweighted for me and also the widest width of the tire? Thanks a million!
Ttyl, Fahn
Leave it to Shiggy
http://mtbtires.com/site2/tire-specs/78-650b--275q-/107-650b-275q-tire-specs
BTW, my Negegal 2.35 was a loose fit on the Stan's rim with yellow tape. It was a bit dicey to mount up tubeless. It eventually stopped seeping and began holding air yesterday. I took it out for a spin today and it seems OK.
FWIW, my first 650b Neo was much tighter and set the bead without any sealant on the first air up.
Discussion Starter · #3 ·
Thank you! I bow to your greatness (and Shiggy's)!
Here's what I don't get- My brand new Bonty XDX 26 x 2.4 tire is literally bigger than any of those specs.
I'm 353mm axle to ground vs Nev (27.5 x 2.35) 354mm
Bonty XDX- Tread width 65mm Casing 60mm
Nev Tread width 61mm Casing 56.3mm
The Bonty is on a 22mm rim
Ttyl, Fahn
1 - 3 of 3 Posts
