those are both the correct tools, and those are the correct instructions. good luck!
You need the FR-5G -or- the FR-5 to remove and install the cassette, not both. The BBT-9 will work to install the external BB. Consider the BBT-19 instead if you're the type of buy who likes to use a torque wrench to make sure everything is to spec.sneakyt said:On a side note, there's a good sale for Park Tools so I want to get a couple of things for future installations of SLX cranksets with bb, and SRAM/Shimano cassette. Are these tools right for the job?
"8 sided stud"? Do you mean the round plastic tool on the end of the BBT-9? Every Shimano (outboard BB) crankset I have bought included the tool required to load the crankarm against the bearings.sneakyt said:As for the tools, I'll go with the FR-5G and the BBT-9 because it has the 8 sided stud for Shimano cranksets. If I go with the BBT-19, I still have to buy the BBT-9.
Yes, that's the one. In Shimano's installation instruction, the tool is TL-FC16. I've tried to find out whether the SLX cranksets come with the 8 sided stud tool or not, but no luck. Called Shimano and just got an un-ending automated voice. I'll call some lbs to find out. If it does come with the tool, then I'll definitely get the BBT-19. Thanks for the info btw.anotherbrian said:"8 sided stud"? Do you mean the round plastic tool on the end of the BBT-9? Every Shimano (outboard BB) crankset I have bought included the tool required to load the crankarm against the bearings.
Over the past couple years I've gotten them with two XT cranksets, one low-level Deore, and one SLX w/bash cranksets. I'm absolutely positive they come from Shimano with them. I'd send you one of my many spares if you wanted (would require a SASE).sneakyt said:Yes, that's the one. In Shimano's installation instruction, the tool is TL-FC16. I've tried to find out whether the SLX cranksets come with the 8 sided stud tool or not, but no luck. Called Shimano and just got an un-ending automated voice. I'll call some lbs to find out. If it does come with the tool, then I'll definitely get the BBT-19. Thanks for the info btw.
