I just got back from an epic western N. Carolina trip that could've been a disaster. I have a Santa Cruz Blur XC and after trying to eliminate a creak, I applied red loc-tite to all my pivot bolts (I should've used blue). I sheared off the heads of two bolts while in N.C. and was luckily able to find a replacement bolt at a shop in town. The problem is that the other one is stuck in there and when I need to remove the others, the same thing will happen I'm sure.
Loc-tite recommends using heat to remove bolts sealed w/ red but if I do that, I run the risk of my aluminum frame being warped. Does anybody have experience with red loctite and using an EZ out? This seems like my only option unless someone has something else to suggest. Please help me save my 6-month old frame.
