1 - 9 of 9 Posts
I just got my Mongoose teocali, since its got an interupted seat tube, I am wondering if there are any telescoping Ibeam seatposts out there?
I found the Titec Knock, but that is for traditional seats only.
PS. Which is the best traditional one? (AND CHEAP!)
Thanks.
none are made, period. I've tried, as I'm looking at getting a teocali also. You'll have to go with one of the titec posts, I think they make a few that telescope, and get a conventional saddle.
I recall that there used to be a similar product like the Titec scoper for the lower. It allowed you to fit a smaller diameter post in inside of it. Universal and Cambria used to carry them, but I haven't seen it in some time.
I have a Titec Scoper post on a Mountain Cycle Fury. Mine is the same 31.6 size that the Mongoose uses.
The outer post(frame end) is 31.6 and the inner post is a 27.2.
If you dont mind spending the extra money You could probably use any 27.2 post for an inner post.
Im using a 27.2 Thomson as an inner post with the Titec outer and clamp with no issues.
Discussion Starter · #6 ·
ic, so id have to get a titec scoper + a 27.2 inner post (I beam compatible) and it would work right.
Yes... unless someone makes a telescoping I beam post but I have never seen one.
crazylax42 Sorry I don't remember what the length was. I cut mine down the day I got it.
1 - 9 of 9 Posts
