So I posted about blowing up the Mattoc on my 'park bike.' Which is just a Commencal Meta V4 with downhill tires.
Decided that while I'll eventually fix that bike and maybe repurpose it a bit (back to 'gnarly trail bike' instead of 'don't try to pedal this'), I want to build an actual downhill bike.
Nothing crazy. I've had some rentals that were of the 'race-ready' sort, and they were miserable. I rode a Commencal Supreme that felt huge (29er) and murderously stiff. Ended up coming down hard enough on a jump that my legs buckled a bit and my butt hit the rear tire...which then fired my genitals at the back of the seat like a pitching machine. Luckily, I ended up taking it in the legs, sporting two basketball-sized purple bruises for a month. They looked like the wings of a giant, hairy, ugly moth (I'll let you guess what part was the body).
Anyhow. I acquired a GGDH frame with a Fox coil shock (can't remember the model, but I've ridden the air version a DH bike and found it perfectly adequate). I can buy or rob (from my broken Commencal) most of the other parts I need, no problem.
But the fork? I got no idea.
I've ridden Boxxers. Different versions with different levels of adjustment. At least one coil and a few air. They were universally terrible, the worst being the coil version on an XL rental bike, which I think was sprung for a 350lb rider.
I've ridden Foxes. They were adequate. My favorite rental was a Pivot with a Fox air shock in the back and a Marz fork that I remember being told was 'just a rebadged Fox 40.' Which is what it looked like.
So RS is out, Fox is probably out (better than RS, generally not great, with their good stuff being waaaaay too expensive). I'm just looking for the best of the 'other guys.'
Since this is gonna be for park trips, reliability is paramount. But it won't trump having a fork that is at least SOMEWHAT forgiving and comfortable. It can't be stressed enough that my 150mm Mattoc ate up DH trails better than any DH forks I've tried. The latter only came into their own when pounding through really rough ****, which still felt...really rough...but they could hold the line where the Mattoc couldn't.
So...no big order...just super-supple, super-reliable, and not too expensive. LOL.
Dorado? Seems like reliability ain't great.
DVO? I think there are two offerings but know nothing about them. I have a Sapphire and would describe it as 'what Rockshox wants to make, but fails at.' I.e. it is an aggressive, hard-charging fork that does what it can to maintain some comfort, rather than feeling like a big, dumb bulldozer that technically 'works' and can probably handle a tomahawk down the mountain, but has all the sophistication of a brick to the face.
MRP? I believe their fork only goes to 190mm, which would probably be okay. Rear travel on the GG is 195 or 205, so a 190 fork seems a little goofy on paper, but I'm sure it would work fine and I could run an angleset if I wanted to get that little bit of slack back.
Who am I missing that is currently in wide production? I see used forks like BOS's that are interesting, but I know nothing about them and am dubious about support.
I'm almost wondering if I should just get a used Boxxer or 40, solely for the reliability of the basic chassis and wide parts availability, then just send it in to Avalanche to get a competent damper retrofitted...
