How about slightly shorter, very slightly, and lower rise?Tetsujin808 said:Remember if you go with a shorter stem with the same amount of rise, the net effect will be the bars closer AND lower.
http://www.leelikesbikes.com/stem-lengthrise-for-a-trail-bike.html
Yes, it's a Cannondale stem. I'm pretty sure its a 20 degree rise. It's an 08 F5Tetsujin808 said:Is this a Cannondale stem? I did a quick google search and looks like they came in 20 and 5 degree rise. If you can find out what rise yours is, we can do some math to figure out what combination you would need.
http://gallery.mtbr.com/showphoto.php/photo/170127
:skep: This is where I went downhill in math.Tetsujin808 said:So if my trig is correct, going from a 110 to 100 with the same 20 degrees of rise would give:
((110*cos(20) - 100*cos(20)) = 9.4mm closer
((110*sin(20) - 100*sin(20)) = 3.4mm lower
