I want some light disk brakes calipers what do you sugest?
Ditto!mward said:Magura Marta SL's.
I should go in to more detail re: the shredding of pads and loss of modulation.mward said:I have used my martas in horrible conditions, muddy race when it was raining and didn't have a single problem. Never had fade, never had modulation problems. I don't do extended downhills on them, they're not downhill brakes, and we don't really have any extended downhills in missouri. FOr an xc bike, they're perfect. For freeride or all mountain as spooky is describing, maybe you want something a little beefier. The martas don't have the heat dissapation of larger brakes. I've never had a problem with mine, ever, fwiw.
Don't get me wrong, I really liked my B4s (B4 SLs and B4 SL+s)...for me, they'd be a very close second, just behind the Marta SLs.Spookykinkajou said:I thought they were not as good compared to the current formula b4 brakes i use.
Yes, both the Formulas and Martas *feel* pretty close (and that's good). Over the years, I've found the Formulas to have the best feel (modulation) and incredible power. Some other brakes had more power, but just didn't have the *feel* of the Formulas. Then, I tried the Marta SLs....wow! Over the year I've been riding on my Martas, they've worked their way-up to my brake of choice. Of course, your brakes may vary.Spookykinkajou said:Braking power between the two brands are equal as is modulation.
For me, pad-wear on the Formulas would be equivalent to the Martas....both are excellent. Even after TransRockies, I still had pads left despite the mud, water and DHs.Spookykinkajou said:Pad wear is MUCH better on the current formula brake pads. I broke the formula's in at the exact same place as the Maguras in very similar conditions(pisgah) and they hands down outperformed the marta's in every way.
Without question, the Marta SLs are much, much more expensive than the Formulas. With that said, and knowing their performance (head-to-head), I'd probably give the cost/performance title to the Formulas since they are soo close to the Martas in performance, but a lot less expensive. Perhaps a better comparison would be the Martas (non-SLs) versus the Formulas....the only diff between the Marta and Marta SL is the carbon lever, which does feel nice on the fingers, but doesn't really add that much (other than some nice bling) to the SLs.Spookykinkajou said:The price was much nicer for the formulas, from thorusa, being only 175 for the pair while the maguras were twice that!
but I'm reluctant to get another set of Magura brakes after my experience with my Claras. Granted, the Claras were deeply flawed, but I was surprised that I really got the red-headed stepchild treatment when I tried to warranty them. I felt like I got second rate service because I bought a 'cheapo' brakeset.1speed_Mike said:Ditto!
I've got a set of Marta SLs on my SS and my FS-XC rides and both are fantastic! Each set is ~705g/set (fully bled, uncut, all bolts, rotors, etc.). Lever-feel is second-to-none (a close second would be the Formula B4 SLs), modulation is predictable and consistent, as is power...be it, dry or wet, hot or cold (-25C). And, they are quiet (unlike my Hope Minis)! Disc rub? Nope (unlike my XTRs)! Pad-wear? Excellent!
I've owned and raced on alot of discs over the last couple years (Hope C2 Pros, Hope Minis, Hope Mono Minis, Shimano XT/XTR, Formula B4s, Formula B4 SLs, Formula B4 SL+s, and now Magura Marta SLs). FWIW, all of the other brakes are gone and only the Martas remain. Why? Because they've proven themselves to me again and again.
