1 - 12 of 12 Posts
· Registered
The "x" notation sucks because it is mathematically wrong to think of gears as 34x20=680, 32x19=608, or 32x18=576.
Provided you are comparing gear ratios for bikes of the same wheel size you can simply consider it a ratio and use the "/" notation. When you switch the notation it becomes simple. 34/20=1.70, 32/19=1.68, and 32/18=1.77.
With the proper notation and a simple calculator you can easily see that 34/20 is slightly bigger than 32/19 and slightly smaller than 32/18.
If you need to also consider wheel size the math gets more complicated so you will want to use an online calculator.
Bicycle Bike Gear Ratio Speed and Cadence Calculator
For most people doing off road a ratio between 1.65 and 1.85 makes sense. The best performance will be a gear that keeps you in your optimal power range most of the time This depends a lot on the terrain you ride and your fitness.
If you are riding single speed on the road you are likely a hipster and as such the actual gear does not matter because it's a style thing.
Good luck.
· Registered
32/16 = 2. That means for every turn of the crank, your rear wheel completes 2 full rotations.
36/12 = 3. So for every turn of the crank, your friend's wheel completes 3 full rotations.
Your buddy's gearing is way harder than yours. (Again assuming that the numbers are correct - that is a pretty weird combo). 36/18 would be exactly the same as 32/16.
· Registered
I think its suppose to be used more on paved walk ways and streets. I dont think he could handle some of the trails I use. Also his bike has 29" wheels vs my 26".
Almost certainly that bike is NOT using 36x12 gearing then. Taking a look at the bike on Walmarts website, it looks like it comes with a free wheel and I'd guess about 18t. (I can count 12t easily, not counting what is behind the seat and chain stay, so it's definitely more than that)
· Yeet so hard
If this bike is actually from Walmart don't even think of taking him off road unless he has really good medical insurance and doesn't like his teeth.
1 - 12 of 12 Posts
