1 - 20 of 30 Posts
I've been biking for a few years now, but not consistently. I don't know a whole lot about bikes either. I have a Trek 4300 Alpha 2002 I think. Lately I've been doing more and I want an upgrade, but I don't have a ton of money. I know I want something with discs and a better fork. I got a max of about $700, what's the best all around bike for the price? Would it be better to upgrade some components on mine? Thanks
Picture Unrelated
I can't see it being worth putting money into your 4300. How often did you change the chain? How much did you take care of it? How does the suspension feel? How about saddle, grips, pedals, reach... How does it feel when you ride it? Is there anything you would change about it? You can't throw money at an entry level bike and expect it to start performing like a race bike, unfortunately it doesn't work that way. Certainly if the bike is dialed for you then it will be worth putting some money into, but with a 9 year old bike I don't think you're going to get much value that way.
$700 in the new market might get you a good deal with the end of season sales going on, it really depends on what the shops in your area have in stock. You could also try to find something used. My suggestion is don't buy anything used or off the internet unless you can ride it first. First and foremost your bike has to fit, personally I'd go to a LBS to buy a bike, but to each their own. $700 is a decent budget, test ride everything you can get your hands on and see how things compare to your old bike.
Discussion Starter · #3 ·
Thanks for the response. I see what you're saying about upgrading the 4300, it's old and needs one of everything too. I've been looking at a bike I found on craigslist, it's a Kona Stuff. I'm going to meet with the guy today so I can test ride it. Are these good bikes? He upgraded the fork to a Fox 36 Talas RC2, I don't know a whole lot about bike components but I've heard fox forks are good. He's asking $675 for it.
Picture Unrelated
All that matters is that you like it. If it fits, and you like it, then it's not a bad bike.
Picture Unrelated
Ok thanks, there's also a Trek Ex 5. If I save a little more I could get that. How does that compare to the Kona?
Impossible to say without having the two bikes in my hands. One could be completely clapped out making it worthless but I can't say. I'm going to default to my previous answer.
Dont waste your time
i like what zebra said cause he brings up a valid point, dont upgrade something that cant be upgraded. Im a skilled Mountain bike Mechanic myself and am in the process of building my own bike but when i was younger i had to learn the hard way that even if you put $1000 into a bike ods are its still gunna be the bike you had before and it still wont be to your liking. And dont forget that finding a bike that fits you can be tough but as long as you do your research and dont rush it you will be fine, hope the words helped, see ya
Picture Unrelated
You might need to adjust the hub.
+1
You can try it yourself with the help of Park's website or you could take it into the shop and have them crank out an adjustment in a few minutes. To do it yourself, you may need some cone wrenches depending on the hubs.
Picture Unrelated
It's a 20mm thru axle and I tightened the cap on the end with an allen wrench and it seem fine now. Is this a normal problem? Could I use a little lock tight?
There should be pinch bolts that keep the axle from backing out, but yes you should make sure your axle is tight before every ride.
Discussion Starter · #18 ·
Took the bike out today and had a blast, first time I really did any jumping. I've almost maxed out the front suspension. On the fork there's the rebound adjustment and the travel adjustment, on the bottom of the fork there's a cap. If you take that off is that a compression adjustment? For the fork do you ever need to redo the fork oil? Also I noticed that I was smelling brakes. They were getting super hot, should I upgrade the disc size? Thanks
Picture Unrelated
Might be compression damping at the bottom, I'd have to read the manual or tech sheet. Maybe someone with that fork will chime in.
The manual will have service intervals including fork oil changes. While most people don't follow those guidelines, it's safest to follow the directions for fork longevity.
Are you using both your brakes? Most of your braking power comes from the front brake and that's a common reason people heat their brakes up too much.
1 - 20 of 30 Posts
