Posted in Clydesdale Forum also, may fit here better.
Hey all, been riding Hardtails most of my life, and just purchased a lightly used 2019 Stumpjumper. Size XL, fitment is great, although may need to make small cockpit adjustments.
Hoping someone can lead me in the right direction with Suspension upgrades though:
First, 74 inches, 255 geared (camelback, multi-tool(s)) using clip Shimano X3's. (Trying out flats next week). I don't do a ton of jumping, but the terrain that I ride in Upstate NY has quite the downhills, technical climbs, and flats with large shale, cave-type rocks, etc. Of course roots, and more roots.
I have had the bike on 2 good rides, although still feel 100% more confident on my Hardtail if I am being honest.
So, here are the questions:
The front fork is a 150mm RockShox Pike RC, the rear a RockShox Deluxe RT3.
At my current weight, the front fork is a non issue, works as it should, might add a spacer to run a bit lower air pressure. However, when compared to my Marzocchi Bomber Z2, I actually prefer it to the Pike, but again, not too many rides on the Pike. I do have the kit to convert the Z2 to 150mm, so something to ponder.
The MAIN issue is the rear shock, at full air pressure (300psi), and going through all the correct setup directions, and even having a buddy who I trust explicitly, I am bottoming it out, and there is no way I can get near the 20-30% sag. We were taking about the possibility of going with a coil-based rear shock. I have no idea where to begin looking, or what even fits, or how to measure. Hoping someone can give me some help. Also, zero spacers installed, would that make help or just mask the problem. Cascade Compontent rear link is on the bike also.
Thanks for hearing me out!
