Did this to my KM, still not 100% happy.
I used to run 120mm stems with 11º Salsa Bars, and 140mm with H-bars.
Now there's ~100mm x 40º with a 6mm taller (redline) fork, and 35mm more spacers under the stem. It still feels like a long and deep stretch. I cannot comfortable ride the drops. Looking around for either a cheap fork with longer steerer to add spacers, or one with longer axle-crown. The latter would reduce reach by itself, some 60% of the extra length will be deducted from yor reach.
My ideal road bike top tube must be around 580-590mm. The MTB's I've called ideal were between 616 and 648mm. I made the mistake to get one custom and one stock CX bike with 600mm stem, making even a 100mm stem feel "long". Short stems on road bike don't feel nice. Nervous, due to the narrow bar I presume.
I'm now looking to get 420mm rather than 400mm forks for both my CX'ers, not easy or cheap. For more relaxed handling, and possibly allowing a 110mm stem.
With the MTB frame, at least you'll have a long front center, offering stability to some degree. If you can handle a 17" frame for seatpost length, try an find someone to trade frames with (get an MTBR classifieds ad). The ~3/4" shorter top tube will help. Heck, I may have to do that with the beloved KM if I don't manage to get preferable handling and position. Or just give up on the Midge and go to tried and true (for over a century) swept trekking bars that I know I love, and work 100% with MTB frames. I wanted the Midge on the KM for commuting and the odd supercentury where the tops would be the optional position, not for all of the ride. That means TALL and SHORT, I've found.
The Redline Flight would be a much better do-both bike in this (Midge on MTB) respect than the Monocog. Top Tubes are ~20mm shorter for each size, promoting a "normal" length stem. That's a good 2" frame increment's difference! Also, steering geometry is a bit more"retro", slacker head tube angle, more offset, for the same front center and fork trail.
Now I've got a Flight on it's way to me, but for now I'm planning to treat it as a marvellous steel MTB, and I don't onsider Midge a real offroad option for myself, when I can get the likes of 17º Salsa bars and custom Black Sheeps to rock my bike world.
I'm in bad luck with my long legs, I really need a 21" to get proper seatpost insertion even with 410 and 450mm seatposts, others my height might get away with 19" and get decent fit with both MTB and Road bars. It will never be easy though, the difference between the bars really is a full 2 frame size increments in terms of reach.
