1 - 5 of 5 Posts
KRISDALA BAKA!!!!!!!!!!!!
Here's what I posted on the Jamis thread, maybe this forum is more appropriate, but here goes
Aaarrrggghhhh!!!!!!!!!!!!!
Someone please have the answer to this one! The top tube pivot on my 04 Dakar XC will not come apart. I pull the bolt out on one side and when I go to do the other side the aluminum axle inside just spin with the bolt, thus being unable to extract.
I tried putting the other one in and tightening it down to get a good turn on the stubborn side to no avail. I ended up trying to jam an allen wrench in there a applying pressure up or down on the inside of the axle and breaking the bolt free...did not work.
Attached is a drawing of the rear suspension of my bike, note that item #1 is spinning in the top tube shaft as I turn item #4 to remove, unsuccesfully.
Please help me!
http://www.jamisbikes.com/usa/tech_l..._TECH_PAGE.pdf
Can you put a small punch into the open side and just press out? From schematic looks like it will work.
Discussion Starter · #5 ·
Funny, that was the same suggestion, more or less, that I got in the Jamis forums. Thank you, I will try it tonite whent I get home from work.
1 - 5 of 5 Posts
