Hello,
I just received my two SSC P4 LEDs. One's about to go in my Cateye EL-530 tonight. The other one is now going in a Brunton Glorb camping lantern:
http://www.brunton.com/product.php?id=304
I unsoldered the LED from the Glorb (who comes up with these names?) and then took a voltage measurement across the two open contacts. I get 6.0V. (This lantern takes 4 X 1.5V AA cells). The specs on the SSC P4 say max voltage is 3.8V, so obviously I'm looking for a way to drop this down to 3.8V while sustaining max current.
Possible options:
The driver board is about 1.125 inches in diameter, but it's shaped like a "D" to fit in a holding ring that contains an ON/OFF push button. Therefore, I'm not sure that swapping the driver board is viable.....or is it?
Another thought was to add a resistor in series or parallel with the P4, but I'm not sure of the part value or it's effect on reducing current to the P4.
The other thought was to look around to see if there's a 6V to 3.8V voltage regulator out there.
BTW, the Glorb has a good size aluminum heatsink, so keeping the P4 cool shouldn't be a problem once I add a little more thermal paste.
Anyhow, if anyone has any suggestions, please let me know.
Thanks,
Keven
Possible options:
Thanks,
Keven
