1 - 4 of 4 Posts
I'm still learning how to custom build and am confused on the compatability between the Canfield brothers Jedi frame and the TRUVATIV X0 10-Speed Crankset + SRAM GXP Bottom bracket.
The frame says it has an 83mm bracket shell. The only crank arm i could find that says 83mm is Canfields own, yet they do not sell chain rings. And as far as i can tell, there isn't a single bottom bracket in existance that supports larger than 73mm shells. Are these parts compatable? If not, what is?
Fat-tired Roadie
You can probably stick aftermarket chainrings on Canfield's crank, if you go that way. You need to match the number of bolts and bolt circle diameter.
1 - 4 of 4 Posts
