1 - 3 of 3 Posts
Hello i am fairly new to riding i just got myself a new bike its an Iron Horse Maverick 1.2 and it rides really well it is brand new however the handle bar post seems a bit loose (i can shake it and move it back and forth) i have tried tightening it and no luck if anyone knows how to fix that please help.
Cody
Your local bike shop should be able to fix it. It sounds like the headset/fork steering tube is loose. Loosen the two bolts on the stem bar and then tighten the top cap screw maybe a turn and see if it tightens up. That might solve the problem. Inexpensive bikes will have inexpensive headsets with bearings that can fall out. A decent headset plus labor is probably around $65 or so. Check out Park Tools website their is a lot of information there for the do it yourselfer.
Singletrack Slayer
+ 1 for loose headset. Do what he said and it should be good. Do not over tighten the top cap, it is a compression cap, tight enough to still have smooth movement but no slop back and forth.
1 - 3 of 3 Posts
