1 - 5 of 5 Posts
Baby Bear is in the house
My current ride (SS rigid 650B) has a 580-mm horizontal top tube (HTT), running a 75-mm 10deg stem and a 25-mm offset seat post. The frame is a Schwinn Moab (26er), and I am not at all too keen on the rear tire clearance with my 650B conversion. The 2.0 Quasi-Moto fits, but just barely. I don't ride in mud, but am concerned with little stones getting stuck down there and gouging the aluminum stays.
I built up this frame from scratch and always felt a tad stretched out with the 9deg riser I had on the original build. Switching to a 25-degree sweep, 50-mm rise, riser bar was like night and day. I don't know if it was the shorter reach, or the higher front end, but it was sooo much more comfy. I just recently got a Titec H-bar, which, even with the greater 45-deg sweep, has brought my grip position approximately 20mm forward. The "tad stretched out" feeling returned, but I am now a fan of this bar so I'm sticking with it. I might get a shorter stem.
The frame I'm considering as a replacement has much better rear tire clearance (maybe even enough to fit a 2.3 Neo-Moto), but I am between sizes. The small has a 560-mm HTT, the medium, 585-mm.
My question is, should I go for the small and keep my current (75-mm) stem, or get the medium and a new shorter (50-70mm) stem to go with it? If the latter, I could also get a zero offset seat post, but my current, suspension post works so well, I don't think I can part with it :p
What are the pros and cons of going with either setup?
I'm not taking it as gospel, but FWIW the Wrench Science fit calculator shows I need an overall reach of 640mm. I like short stems and wouldn't go over 90mm, so this limits my HTT options to a minimum of 550mm. The WS fit system doesn't account for stem rise or seat post offset.
'appreciate any input.
I'd say get a frame that fits without having to resort to other fixes. In your case that would mean looking for another model and/or manufacturer. However a 75mm stem is pretty short and 90mm is not anywhere near long.
Discussion Starter · #3 ·
Thanks for the input.
I'm pretty set on getting this particular brand/model, as there aren't than many choices where I'm from (the Philippines).
Like I said, I prefer short stems and am pretty used to the 75-mm I'm using now. I can't imagine running anything over 90mm, and can probably even go as short as 50mm.
I guess the gist of my post is, should I go long TT/short stem, or short TT-long stem? What are the pros and cons of going either way?
Stem length will affect handling somewhat but not a ton. What are the other specs on the two sizes? Chainstay length, headtube length, frame angles, trail, etc. They also have an affect on fit and handling. Since you have a preference for short stems it seems logical that a longer TT/shorter stem would be more up your alley. A longer TT also means a larger frame in general. There's pros and cons to larger frames but I'll take a larger frame over a smaller one when inbetween, of course assuming both fit reasonably well. Handling may be a touch quicker on a smaller frame but larger frames can be more comfortable, better balanced and climb and descend better. I've ridden a frame on the small side for me for several years. It was ok but when I got on a larger frame I enjoyed it a lot more, even though the larger bike was a pig and outweighed the smaller one by a large margin. I've now gone to a much lighter setup on a new frame that matches the size of the old larger frame and am even more happy.
Discussion Starter · #5 ·
Apart from the seat and effective/horizontal TT lengths, the 2 sizes are virtually identical in other measurements (exactly the same model, just different sizes -- small & medium)
Makes sense.
I understand and agree on the balance part (thanks for verifying my musings), but not so sure about comfort, because as I said, my current ride (which is only 5mm shorter than the M frame I'm considering) feels a little too big.
Again, thanks for your thoughts.
1 - 5 of 5 Posts
