1 - 11 of 11 Posts
I'm noticing I have some flex in my rear wheel and its also causing my possible problem with my rear disc to rub against the pads when I get on the bike, but its fine on the stand. I want to make sure its not the hub causing this flex, but this is my first time doing this. What is the proper procedure? Oh and I included a diagram if it will help. Thanks!
Discussion Starter · #5 ·
Got it. Thanks
For future reference if anyone knows how to properly adjust this rear hub, can you provide me the proper steps?
Does your set of xc ones have a preload adjustment sleeve? It should sit inside the rotor side end cap and you can rotate it with a small allen key to add or release some bearing preload. But as mentioned by other posters, no clunk means proper adjustment.
Reviving an old thread here... Ok so my Easton XC One rear hub IS clunking when moving it side-to-side. Do I use the +/- adjusters on either side of the hub to tighten and tune this out? Thanks!
Found it. Just turn the pre-load adjuster clockwise a bit using the end of a spanner tool and done!
1 - 11 of 11 Posts
