1 - 11 of 11 Posts
:\ ping of death
Im trying to remove my crank arm but Im not sure which type it is. It looks like my BB is square-tapered but is this crankarm a one-key system or does it use a lock ring? I dont have a crank puller but if its a one-key then I dont need one right? I went to parktools site and read up on the installation/removal. Informative but useless without the proper tools.
Basically what Im trying to do is remove all 3 chain rings. But the chainring bolts appear to have a capped side that just keeps spinning and spinning, obviousy because they arent threaded.
Here are the pics:
Cleavage Of The Tetons
Get yourself a crankpuller...
If you simply can't rationalize that, just take the bolt out and go do some urban riding...the crank will eventually come loose, just don't ride it loose. Your cranks are not 'one key'. Good luck!
No, square-taper (all manufacturers) is as, stated four equal square sides. ISIS (Raceface, FSA, Truvativ) uses 10 splines to which the crank engages and the Shimano proprietary version is Octalink which has eight engagment splines. The newest crank/bb interface(s) have the bb spindle attached to one of the cranks and the other is attached via a fixing bolt. Confusing isn't it?
phoeneous said:
Is square-tapered the same as ISIS Splined?
Live 2 Ride
I have the very same Truvativ cranks. The chainrings can not be removed from on another. The chainring bolts are not removable. the chainrings are meant to be replaced all three at once. To replace all three there is a BIG bolt on the back that hold all three chainrings on the crankarm.
:\ ping of death
Discussion Starter · #8 ·
I was afraid of that. After studying it for a few minutes yesterday I realized that the cap on the left side of the granny and the screwhead on the right side of the big ring are all one piece. Fooey!
Can I access that bolt without removing the crankarm first? Do I need a lockring removal tool or will a crescent wrench work?
Thx.
Before you get too carried away, try sourcing the replacement chain rings. As they're probably OEM, might be easier to purchase a new crankset with normal removable rings.
Thx.
:\ ping of death
Discussion Starter · #10 ·
Im actually going single ring. I already have the ring and the bash guard is on its way. I also have top change my crankarm(s) and BB for it all to work together.
This is will be my new setup:
FSA V-Drive Armset
FSA Platinum BB
Azonic A-Frame Pedals
BlackSpire MonoVeloce Ring (4 bolt, 104mm, 34t)
RaceFace Bash Guard [4 bolt, 104mm]
The only thing Im missing is the bolts to secure the crankarms + ring + bash together. Where can I buy these?
Any good bike shop should have them.
FSA V-Drive Armset
FSA Platinum BB
1 - 11 of 11 Posts
