I had an issue recently where it appeared as stans rim with yellow tape and valve was leaking from the stem, stem was correct, sufficiently tight. Turns out there was a tear in the yellow tape on the opposite side of the rim (letting the air into the rim cavity and finding it's way out the valve stem hole).
