1 - 5 of 5 Posts
I’m on the edge to bay a YT Jeffsy 27 CF 2018. But I’m not sure for the size as I’m just in the middle of size M and L.
I’m going to use it in some smaller bikeparks in Sweden and Harzen (not the heavy stuff).
I´m normally riding XC (have done it for the past 10 years) so I´m new in the trail/all-mountain game and therefor seek some advice for the size of the frame
I’m 176 cm height and have normally a saddle high of 73,5 mm with a 175 mm crankset (my inseam length is app. 82 cm).
The geometry of the YT Jeffsy is the following
Reach: M – 435mm L – 455mm
Top tube effective: M - 602mm L - 625mm
Wheelbase: M - 1.173mm L – 1.204mm
Seattube C-T: M – 450mm L – 480mm
Headtube: M – 110mm L – 125mm
Slower But Faster
I was in the same dilemma (and am just very slightly taller than you) when looking at this model Jeffsy. The long seat tube length on the large was the issue getting the saddle height right for me a full seat post extension. In the end I went in a different direction and landed on a Trek Remedy.
also was looking at a jeffsy at 180cm with a 81cm inseam and couldn't see the bike fitting. you might get away on a medium if you feel ok with that reach, or are ok with swapping out the dropper for a 125mm one.
BrassBalled DropbarNinja
Think you might have the geo numbers from the 2017?
https://geometrygeeks.bike/bike/yt-jeffsy-27-al-and-cf-models-2018/
I'm 5'8 on a good day with short legs and long arms and had some time on a medium 2018 Jeffsy CF. Thought the bike fit pretty well actually though the 150mm dropper that came with it was definitely way too long and I would've rather had a 120mm or even a 100mm dropper. Note that I also run the saddle further back as well and am not really a fan of these steep seatpost angles as it makes it trickier to load the rear axe on technical climbs
Here's a video on my thoughts of the 2018 Jeffsy CF
1 - 5 of 5 Posts
