1 - 2 of 2 Posts
I was wondering if you are using 1 spacer on your xtr cranks on the drive side or non drive side. It seems you have a better chain line with it on the non drive side.
Next problem on the 09 frames you have to run the cable housing through the housing holders on the top tube. I have been seeing that its digging into the housing and the paint where it runs through. What have you found to stop this?
mutaullyassuredsuffering
Drive
I run one spacer on the drive side. My cable routing is different so I can't help you there.
1 - 2 of 2 Posts
