Not sure it is possible. If it can be done you will need to go to a larger rotor.DIYguy said:I need a disc brake adapter 74mm to 51mm. I have a Manitou Skareb fork. I want to use a Coda Disc caliper that is the 51mm size. I would like to use 160mm rotor, but could go larger. Any help will be appreciated. THANKS
Check out our eBay Store. We have the exact adapter you need. You will need to increase rotor size, and we have those too.DIYguy said:I need a disc brake adapter 74mm to 51mm. I have a Manitou Skareb fork. I want to use a Coda Disc caliper that is the 51mm size. I would like to use 160mm rotor, but could go larger. Any help will be appreciated. THANKS
