I have a Niterider 13.2V dual beam halogen light with a dead battery. I'm considering converting to an dual LED instead of just replacing the battery (which is pretty expensive). I'm looking for advice on a simple conversion. The trickest part is finding the correct diameter for the replacement optics. My current halogen lights are 35mm in diameter, but I think that I can make a 38mm optic work (with a little filing on the housing). I've found reflectors only, but cannot find any flat lenses. I've also found some optics from Cutter. Here is what I'm considering so far.
SSC P7 C-Bin LED Emitter with 21mm Heat Sink Base (900lm)
http://www.dealextreme.com/details.dx/sku.12721
WITH
Regulated CV/CC 5-Mode LED Driver Circuit Board for Cree MC-E/SSC P7 Emitters
http://www.dealextreme.com/details.dx/sku.20329
(Would prefer a three mode but cannot find one.)
AND
Iris MCE Optic (one Spot and one Medium)
http://www.cutter.com.au/proddetail.php?prod=cut898
For power, I'm thinking of two 3.7V 2800mAh li-ion in parallel per light for long runtime.
Haven't identified a switch yet.
I'd basically re-use the housing from the Niterider, but replace everything else.
Has anyone built something similar? Does this sound like it'll work? Any advice is appreciated. With kids, I don't have a lot of time so want to keep things simple.
Also, I'm sure this info is here somewhere on the forum, but did I mention the kids and very little time situation? Thanks in advance.
WITH
AND
