1 - 1 of 1 Posts
I know some of you have already read this post (see "Flutter" Problem...) ...But I'm desperate....!!!!!
I am experiencing an annoying problem with the front brakes. They are Tektro Auriga Comp's (160mm) and are making a fluttering / whirring sound under moderate to heavy braking at speed. It translates into a vibration at the levers too.This doesnt seem to effect braking performance greatly although I have had the pads replaced due to contamination from the factory. (Had the problem prior to this). I'm wondering if anyone has had a similar problem and/or has an easy solution without having to go back to the LBS?
Cheers
1 - 1 of 1 Posts
