1 - 13 of 13 Posts
I'm having a little bit of trouble sorting through all the info in this forum so here goes... I'm an XC racer. I ride mainly dirt and gravel, but once in a while it rains so I have to deal with some mud. I'm looking to replace my IRC Mythos XC (26x2.1) with something more grippy and light at the same time because I've just been slipping all over the place with these. I've been pointed toward the Kenda Karmas, but I hear they're a bit slippery. Any ideas on a nice front/rear tire that gives great traction, but keeps the inner WW happy?
Bike to the Bone...
I'm not sure how they compare, but what about Continental Explorers? They sound nice. I tried some used ones a while ago and liked them, although they were worn out, I'm thinking that new ones will be great.
"El Whatever"
Nobby Nics / Racing Raplhs... You can't beat them for weight/traction... There are ligther tyres but will compromise traction. There are more grippy tyres, but at the cost of some weight.
i used the kenda karmas for a good period of time. they are very fast, but do lack traction in corners. i have recenly gone to the small block 8's (2.1) and i am very happy with them. yes, they are a bit heavier than the karmas but, the added control/confidence is worth the slight weight plenalty.
I second Warp. My son and I both switched to the Nics and depending on the conditions I'll race with a Ralph on the back. Great overall tire. Sheds mud really well and grips just the same.
Warp on to something
I like large volume tires with fairly aggressive tread and the 2.4 Nobby Nic is the best compromise and weighs in at around 600g, it works everywhere. The 2.35 Small Block 8 weighs about the same weight as the NN, is good on hardpack and floats well in sand but if the sand is on an incline they pack up and don't work well. Both of these tires are very thin so they're more likely to pinch than some other tires.
Discussion Starter · #8 ·
nobby nics and racing ralphs look good and seem to be the universal answer, but they're quite expensive :(! anyone know where I can find these for a relatively low price (sub $60 maybe)?
Harrumph
If you were at all happy with the Mythos, look within IRC at the Mibro's. I had Mythos' for years in varying sizes, and tried the semi slick Seracks(sp?). Now I've got some 2.25 and 1.95 Mibros on the Fixie/SS and XC bike respectively. I'd say both Mibro sizes have better traction than the Mythos and the 2.25 is lighter than the Serac were. And the knobs are spaced wider and are better mud tires than the Mythos, but not super mudder's either.
"El Whatever"
Drop a line to Chad from redbarnbicycles.com... As usual with guys like him or Larry, I can't say the price he gave me, but I will say it was a sweet price.
I actually have a bunch of 2.1" and 2.25" Knobby Nics and Racing Ralphs for sale right here in the MTBR.com Classifieds:
http://classifieds.mtbr.com/cgi-bin/classifieds/classifieds.pl?db=MtbReview&website=MtbReview&language=&session_key=&search_and_display_db_button=on&results_format=long&db_id=110869&query=retrieval
A alternative to the Nobby Nic may be the Tioga Red Phoniex Pro with the cylex casing
128 tpi. Very Grippy tire and very light. Are you running Ust rims or standard?
I use the standard tires with Stans rim strips. I wish I could tell you were to get them cheap however they seem a little less expensive than the Nobby Nics. I have seen the weight vary between 460 and 500 grams. You have got to try this tire I was amazed.
1 - 13 of 13 Posts
