1 - 12 of 12 Posts
Premium Member
assume you mean mini pump...
i have this one... bought it because it also has co2 option on it... 12g unthreaded or threaded co2's... used it a few times when i've had a slowish leak on my bike to get me back to the car... i always carry a few 12g's with me (left over from my paintball days)... if it comes to it i can pump... or if somone needs some air they can pump... it's slow and tedious... but it'll get you off the trail... and thats the point of a mini pump isn't it.
http://www.nashbar.com/profile.cfm?...estoreid=&pagename=Shop by Subcat: Mini Pumps
if u can swing it, get this one... i have the turbo version which had a gauge on it and its the best pump you can get.. airs up a 2.35 tire in about a minute and it has a fold out leg so its like a mini floor pump. i've used a cb mini and a blackburn mini hand pump and they both take forever to pump up a tire. the topeak mountain or turbo morph is the way to go.. i even use it on my road bike
http://www.pricepoint.com/detail/16...ories-37-Pumps/Topeak-Mountain-Morph-Pump.htm
R.I.P. DogFriend
I had one of those (Topeak Mountain Morph).
Pros: It worked really well both at home and on the trail. I especially liked the fold down foot pedal and the fact it uses a hose. Much easier to pump up a tire on the trail and is compact enough to fit in most hydration packs.
Cons: It required constant attention with little things always coming loose and eventually it literally fell apart. I think I paid almost $40 for the one I had.
If it holds together, it really is a great pump to use.
I still have the Blackburn Mammoth pump I bought back in 1996. The red anodizing has faded a bit, but that thing just refuses to die and works pretty well compared to most mini-pumps and is a little cheaper than the Topeak.
you cant go wrong with either Topeak or Blackburn mini pumps. i bought two Topeak Master Blaster pumps a couple years back (one for me and one for my brother), after a lot of use both pumps are still going strong. I believe that both Topeak and Blackburn have lifetime warranties of their pumps.
I dont like C02 pumps unless your an xc racer and you need to fill up a tube ASAP. C02 cartridges are just one more thing that ends up littering the trails or ending up in landfills.
For the life of me I could not understand what anyone was talking about when they said "Co2 ends up littering and ruining trails." Now I understand they are just talking about people throwing the cylinders out on the trail..
I figure if you bring it in you should take it out with ya.
Premium Member
i've yet to see a c02 cartage on the trail... heck only stuff i see is from paintballers leaving their trash...
but i can see where some arsehat would leave em... i got the pump for under $10... i figured why not... i had a bunch of co2 12g still... i'd much rather use them then spend my time pumping a high volume 29er tire haha... also has both presta and schrader valve bits right on the face of the pump...
Premium Member
haha me to... and when I get home i'll save $5 or whatever by patching my tube :)... i think i've got one tube thats got 4 patches on it now... holding strong :) good thing a patch kit is $1 and patches A LOT of tires tires... just don't pinch the tire between the beat... theres no patching that haha
1 - 12 of 12 Posts
