Thanks, a ride buddy recommended that. i haven't seen pics of a derailleur with 3 axles (extender plus the direct mount adapter) so I'm a bit hesitant...
Sent from my moto g(6) using Tapatalk
You replace the b-link on your existing derailleur with that one. it's a little longer than the stock one.
But, you shouldn't need it for an M8000 derailleur on an 11-46 cassette. That derailleur will work natively with that cassette. Something is wrong with your setup, and I think it's illustrated by the fact that your b-screw is all the way out, which you shouldn't have to do.
A few things I see:
*A long cage derailleur is unnecessary for this cassette in a 1x11 arrangement. I have 2 bikes set up this way, and they both use med cage derailleurs. But, you can use a long cage derailleur. That shouldn't have any bearing on this issue.
*Are you sure chain length is correct? Pretty sure mine both have slightly longer chains, which allow the derailleur to tuck up a little more in this gear combo. It may be your long cage derailleur messing me up on this, though. And/or your b-screw adjustment.
*It's hard to see with the way your bike is angled in the pic, but on mine, the b-links angle downward a bit more than yours, which has the benefit of bringing the derailleur farther down and away from the cassette.
I think that your adjustments are off. I don't think you need to buy anything, but you can put a Goatlink11 on there if you want to. It reportedly improves shift quality a touch.
