need a crank puller, parktool cwp-6 or ccp-2?
2710 Views 4 Replies 3 Participants Last post by  eman
I have a square taper crank. Which one of these should I get? I think the ccp-2 is for square taper only, while the cwp-6 is for square taper and Shimano Octalink and ISIS Drive.
http://www.parktool.com/tools/CCP_2.shtml ccp-2
http://www.parktool.com/tools/CWP_6.shtml cwp-6
Is there any reason I should get one over the other?
Is 16-20bucks a good price for them from an lbs, Thats the cheapest I found at the two nearby bike shops.
I wont order online because I need it tomorrow perferably, my chain is horribly stuck inbetween the frame/BB and the granny ring, :( and I want to ride.
1 - 5 of 5 Posts
Your Choice
As a mechanic I can tell you it's more about personal preferance that anthing else. If you ask me I love the ccp2 and the ccp4, use them everyday. But I've worked with some mechanics that hate them. If you do go with a puller like the cwp-6, I suggest getting the Wrench Force one over the Park. I've used both a lot and feel the Wrench Force one is a bit better.
Can't go wrong with any of your choices but I would stay away from the CCP4, the tip broke on the first use when trying to remove an ISIS crankset.
Thanks, I will go with hte ccp-2, since I only have a square taper crank.
well, the shop that said they had the ccp-2 for 16bucks, actually had it for 30 when i went in. jackasses
I'm off to buy the cwp-6 for 15bucks, from a lbs farther away but more reliable.
1 - 5 of 5 Posts
