Need a bottle of guidance for battery options
858 Views 10 Replies 6 Participants Last post by  .40AET
Need a bit of guidance for battery options
Hello Gents,
I have a tripple MC-E light coming from Deesta/Troutie. I need to get a battery pack that would last At least 2:30hrs on high. Could you guys please help me out on what type of battery configuration I should go with..
1 - 11 of 11 Posts
You are going to want some thing like a 14.8 volt 5200mah pack for a good runtime
maybe bigger but certainly not smaller.
mind you dont usually run on full the whole time .
psylence said:
Nope that one has a 12 volt regulater so is no good is there a similar one with out the 12 volt regulator .
You dont need to worry about a switch it will have one and all functions are done in the maxflex software and when not using it you will unplug the battery .as it is not a good thing to store the light connected to the battery in case of accidental switch on which could lead to overheating or battery discharge.
so then, this would be a winner?
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=5164
Troutie, what type of battery connector are you using for the light?
That battery should be good
Connector wise I am not sure yet we are looking at some new ones and I should have a sample soon
or I can just leave a tail on the light for you to put a connector of choice on .
I am no pro at this so excuse me if I give you the wrong info. I did however read on the maxflex tech docs that you shouldn't exceed 3amps. use it, don't use it..
regards
Thys
So i was about to buy the battery i listed above and realized it's stupid heavy. at over a pound it is way too much. So that leads me to these bad boys:
http://www.batteryjunction.com/tenergy-14-8v-4400.html
http://www.batteryjunction.com/tenergy-18650-148-6600-pcb.html
What runtimes would you guys guesstimate i would get with these using the 3 MC-e's on full?
1 - 11 of 11 Posts
