Nearing 60 and adding sag:)
1209 Views 14 Replies 10 Participants Last post by  phorest
As a fluke I'd been running my fork at around 30% sag and shock at closer to 35% sag. I don't bottom out, but I use all of my shock, less about 10mm. I don't take any big hits usually anyway. My 20 year old shock pump was starting to fail. I knew what pressure gave me the specific sag I had originally settle on, which was about 20% in my FOX 36 160mm fork and about 30% in my DPS shock. So after making some changes and servicing, I just pumped them back up to the pressure that I had before. I notice my pump acting kind of funny. It would show right on pressure then a lower one after I pumped it up a little more. I always cycle the forks and shocks every 50 psi when pumping them up. So I bought a new FOX shock pump and found out I'd been riding 25 psi lower on my shock, and about 5 psi lower on the fork.
The thing is, I like it how it rides with more sag. It's nice and plush for an older dude like me:cool: Any of you older dudes or dudettes do the the same?
  • Like
Reactions: 1
1 - 15 of 15 Posts
I don't add any more sag than I used to in my younger yrs, however I will admit I only ride my HT when I have to.
Added cush is the answer to an "old body" question.
  • Like
Reactions: 3
I never rely on what the gauge says when setting suspension. I pump it up to approximately where sag looks good, then ride, adjust as necessary to get the suspension to feel like it's working for me. Then I take note of the pressure on the shock pump. As long as the gauge is repeatable, I don't care what the value is, as long as it's constantly the same every time.
  • Like
Reactions: 4
Suspension guru Darren Murphy (Push industries) says pay no attention to sag.
  • Like
Reactions: 1
Disagree. You need some type of reasonable range to sag, but I don’t run exactly 30% in the rear and 20% in the front, but usually around + or ~ %5 or within that range.
If you run too much front or rear, bottoming out your shock on the regular cannot be good for the bike, or the body.
Too little can just beat you up.
OP: unless the manufacturer says 35% is too much, do you :)
  • Like
Reactions: 1
I'm definitely not going through my fork travel. Even on some pretty good jumps, there's still 20mm left. I'm not bottoming out my shock either, but it's very close sometimes. I'm getting a Float X2 this weekend. That should be an improvement over my stock DXP.
Our local guru Dougal says the same
Do you have tokens in it?
2 in the fork and yellow (medium) in the shock.
This is most likely why. IME (and against most recommendations & theory) I found that you can run more sag with Tokens as the "ramp up" at the end stroke is exponential making it near impossible to bottom out the Fork. I can get full travel (140mm) with 2 Tokens, but it takes a lot and is infrequent.
As a side not, my Fork is in for servicing and I told them to remove the Tokens as I'm going to try it (again) with a more linear spring.
  • Like
Reactions: 3
What alternative method do they recommend?
Darren says cut the o-ring off. Also not to worry about trying to get the full amount of travel. Check out the Inside Line podcast interview with him, it might change your mind about suspension settings.
  • Like
Reactions: 1
I've got added sag happening as well but mine is due to aging and it's not related to my bike.
  • Haha
  • Like
Reactions: 5
I'm about that. Its hard to measure the back as its a coil.
Set your bike to the bottom on the hardest practice hit you are going to do and that's about right.
  • Like
Reactions: 1
Here's the link to that podcast: Darren Murphy of PUSH Industries - The Inside Line Podcast
1 - 15 of 15 Posts
